Waynemarlow
🚴♂️ Mega poster
The M560 is a powerful motor on single track steep trails and rarely are you able to use its full power other than on fire roads and road.
Thank you for the feedback. Which version did you use? Can you look at the calories field, before switching off the system next time?I had to restart the motor to stop that action.
if(MS.torque_on_crank>tq_threshold&&PAS_counter<MP.PAS_timeout)torque_counter=0;//reset counter, if pressure on pedal and pedals rotating
I've added that feature to the v0.0084 now. The new calibration is executed, if the cadence is zero, the PWM is switched off and the idle value is more than 40mV off the first calibration at startup. Maybe the calibration is triggered, if you rest your leg on the pedal at a red traffic light, you have to try it, I have no M560 on my test bike at the moment. You can check the recent torque value in the calories fieldHm, I think we should add a recalibration at runtime
V0.0083Thank you for the feedback. Which version did you use? Can you look at the calories field, before switching off the system next time?
There should be no impact of the used display on the motor behaviour. As long as the display uses the known CAN protocol.bought dz41 and motor makes klicking sounds ...
