Hi Guys,
Hopefully a simple question about the PC vs IOS application,
In the IOS application you need to register/bind to be able to change parameters, do you need to do the same using the PC application?
If so what is the process to get the password?
My translation of the manual is not good, does someone have a better translation or explanation?
12.7 Log in:
The generated version software can be set 30 The controller can only modify parameters when the password is entered. Ordinary controllers do not have passwords, and some controllers are factory set according to requirements. 30 Set the password After entering the code, the user can only view the parameters and status. Click Login and enter the correct 30 The parameters can be modified only after entering the password.
