Bush mechanic
- Joined
- Oct 19, 2014
- Messages
- 95
Hi all, thought I might just put this out there in case someone has made something similar. I’ve had this chunk of copper sitting around for years and have finally got my health and free time to line up to get a few things done I hope!
My plan is to simply cut this large heatsink down the middle, along the line you can see in the photo, and use one half for each of my two phase runners (different bikes). I’m thinking just drill four holes to line up with the tapped M4 holes in the phaserunner and use some CPU thermal paste between the surfaces, relying on the screws for clamping force. The phaserunner is exactly the same length as the heatsink, but an edge of approx 8mm remains on each side if I divide the block in two, and I am thinking of using this to attach some type of bracket which I can easily screw or zip tie to the bike.
Early on I used the PR without a heat sink and found it lasted only 1-2 minutes under load drawing 40A. I then rigged up a small aluminium heatsink with zip ties and thermal paste which I’ve used ever since, this significantly delays thermal rollback and really does what I need 90% of the time, but I’m hoping this thing will take care of that final 10% of hill climbs especially with the cargo bike (200kg bike, 72v8ah molicel pack, 12T Mac in 24in rim).
Any suggestions, experience, ideas welcome! I know this isn’t really a complex project, probably doesn’t need over working, but damn some of you lot are clever, and maybe I’m missing some obvious and cool idea here
