KTM E Freeride - error code 43
Domagoj1
Can someone help. It gives me error 43 - "Fault in the KTM Power pack ". How to solve it? There is no problem with the 12V battery - a new one was installed. The Power pack was also disassembled and all cells were found to be correct - they are all at the same voltage.
Hi,
I had error 43. The vehicle turned off while driving. Took the power pack to the KTM workshop. 2 months later, I got it back with no errors found. I replaced and charged the 12v battery. No more errors for 2 years! Error 43 points to the high current relay in the power pack. It needs the 12v of the battery...
Hi,
Thanks for sharing the information. Do you know what they repaired/changed in the battery at the KTM service?
You misunderstood. The KTM workshop found NO fault. After I replaced the 12v battery, the fault has not reoccurred for two years.
