Justtoby
Hi All,
I am about to start work on a low rider custom chopper e bike. I want the build to work off a mahooosive 10inch rear Chopper wheel and tyre, the sort of thing you would see on an OCC motorbike chopper.
I have sourced a bike chopper frame in steel so I can mig weld it, so the front end is all done and I will cut off the rear forks, add an extension piece and weld it back to allow for over a foot wide on the rear.
I wonder if I can get someone to lace a hub motor in to the rear motorbike rim as it would need to be offset to get the chain on and the axle would need to be much longer...any ideas?
I have 900mm long chopper front forks that come with the frame, I will weld in a BMX bottom bracket to the rear where the seat tube goes down, this will allow the front mounted chopper style pedals to link to the rear and then I will add another bmx bottom bracket alongside to support an extension going out to meet the rear line of the chain going to the motorbike rear end. So there will be 2 chains linked and the MK2 build will probably see a 5 speed cassette under the seatpost tube to allow the pedals to change gear.
If this is too complicated for a rear hub then I will need to lace in a front hub so that only the pedals turn the rear wheel.
So, in summary, how do I get the read hub motor to work in a WIDE motorbike hub?
I had thought of a mid mount hub but don't really like that as it will spoil the looks of the bike.
