wb9k
Hillhater said:Hi wb9k, ..are any of those packs rated at 20kW/kg ?
No, not on paper anyway. The 20 Ah pouch cell is rated for 20C continuous, which by my calculations is 2.64 kW/kg. However, it's possible to get much more from them (about in the ballpark of the stated target here) with the tradeoff being reduced calendar life. How bad the reduction in calendar life is depends on lots of details. I would think thermal control would be the hardest aspect. You want the cells to be relatively warm at the start of the run, otherwise cell impedance will be higher than optimal. At the same time, you don't want them to overheat from the abusive run conditions. From the sound of things, you'd want to pre-chill just about every other part of the system while keeping the batteries as warm as possible without allowing them to overheat (60C max) at any time. Not easy, but that's the nature of such an extreme design I suppose.
http://issuu.com/chargedevs/docs/issue_13/62?e=3746341/8631268 This link takes you to a recent issue of Charged magazine with an article on the Buckeye Bullet. They discuss their rationale for using A123 cells for the project. May or may not be the absolute best cell for this job, but I would think they would be on the short list.
