D-Man
x504
24" wheel
80 volts 35 amps
no load: 55mph
Max S flat (no tuck): 45mph
I don't understand how this has any meaning without the power data like Xter provided = volts & amps.
How do you measure "no load?"
Al
Al
Lift the wheel off the ground and have a calibrated speedo on the wheel.
The amount of 'drop' gives an idication of how much load is on the motor.
D-Man said:
408 Crystalyte brushless
No load - 31.3 mph
Top Speed - 26.6 mph
Loss 4.7 mph
At what voltage?
As for mine
408 Crystalyte, but from a 408/4012 center tapped motor
48V
No load - 29.1 mph
Top Speed 22.7 mph
Loss 6.4 mph
Interesting if you're on 48V. As I suspected, the 408's aren't the same.
xyster said:
x504
24" wheel
80 volts 35 amps
no load: 55mph
That's interesting. My 48V 40A 5303 front hub on a 28" wheel goes 54 mph no load, and usually around 33.5 mph on flat ground. Shows the difference the extra torque makes, as you reached 82% no-load speed while I was at 62%. But considering you're using the higher-winding motor, and smaller wheels, and more power, it doesn't seem like that big a difference. I wonder what you'd get with a 5303, all else equal.
http://endless-sphere.com/forums/viewtopic.php?t=532&highlight=post+load
I know this is not typical as there is something not wright
No load = 48V 35A 406, draw = 0.7A @ 61.5kmh
On road = 48V 35A 406 34kmh
