Well it is a liquid cooled stator. but the windings will be getting hot.bigmoose said:Arlo, here is a link to what I think may be this green epoxy we see on all these stators:
http://www.monti-inc.com/pdfs/hysol_coating_powders.pdf
Note that the green stuff has a use temp of only 130 oC. Yest it cut's through at 330 ish oC. I am assuming at that temperature it cuts like butter.
I am wondering if you guys using 200 oC wire and going to all this trouble should be using good slot paper, like a Nomex 410 calendared aramid paper on top of the green stuff for extra protection.
"Nomex Type 410 is a calendered insulation paper which offers high inherent dielectric strength, mechanical toughness, flexibility and resilience. Type 410 is the original form of Nomex paper, and is widely used in a majority of electrical equipment applications. Available in 11 thicknesses (2 to 30 mils, or .05 to .76 mm), Type 410 is used in almost every known electrical sheet insulation application. Nomex 410, will maintain 300 V/mil (12 kV/mm) dielectric strength for several hours ar 400°C (750°F)."
This you meen for collossus in stock from? The sensors were between 1&2 7&8 and 13&14 so I am sure they were off.. That will make for a lot of problems right there. As for inductance.... Do I want Xnumber of turns on each phase wire? Do the phase wire inductors need to be away from each other? How big of Dia can the coils be or how small? How many turns per phase does it need?Biff said:You could separate the hall sensors by three teeth. Between 18 and 1, 3 and 4, 6 and 7. You could only run that motor with two controllers, unless you used paralel strands as different "motors". That should work, but maybe not as well as running off separately wound teeth.
If you double the resistance, just to make it more controllable, I think you will be dissapointed. The motor will only be capable of half the power, since 2x the heat would be created for a given current. And it might not save your controller anyways. Inductors are really easy to make with some welders cable and any tube to wrap it around, for an air core. , you can make itany inductance you want, and the heat is produced where you can easily get rid of it.
-ryan
Arlo1 said:As for inductance.... Do I want Xnumber of turns on each phase wire? Do the phase wire inductors need to be away from each other? How big of Dia can the coils be or how small? How many turns per phase does it need?
Arlo1 said:Thanks biff i think the thing is we are spining this motor backwards from what it was designed for.
What would be the easiest on a controller? What about a newtral timing and adding the advance with burties bord?
Biff said:I like to use carpet roll tubing to wind air-core inductors. you want the inductors to have the same number of turns. I just use an on-line calculator to estimate the inductance to start.
http://www.daycounter.com/Calculators/Air-Core-Inductor-Calculator.phtml
Wind something which should have about 15uH of inductance and put one beteen the controller and each phase lead. If things run better, take a turn off each inductor and see how that works. Once you figure out what number of turns works, you can measure the inductance that you have (or calculate it) and then make an Iron core inductor with similar properties if you want to save space.
As far as distance between the inductors, I haven't experimented much with that. With iron core inductors it shouldn't matter since the flux is "contained" in the iron. with air core I haven't found any issues with having them pretty close together, The inductors I have been using are about the size of a 1l water bottle, and I have them all sitting together in something the size of a milk crate. -ryan
Arlo1 said:I need a dual trace oscilloscope... I still dont belive how the hall sensor timeing could be right? I feel it was maybe right for rotation one direction and not the other. But.. I need to draw the stator vs magnet diagram again. What I will do is put 9 hall sensors in this motor so I can have a proper hall set for each controller. The halls need to be proper to begin with because burties bord can only start adjusting ~1100 rpm!
Arlo1 said:When it says coil Dia is the the distance of diameter of one loop? And coil length is the total lengh of all the turns of the coil? So if its the total lengh of all the coils you want to keep the gauge of wire as small as you need to make the inducance as hi as possible so you can make the total inductor as small as possible.
Luke mentioned an air core has no losses in efficency what about an iron core? It would proly take some energy away kinda like a iron stator?
Run in series maybe a bit but not enough. And then for 7500 rpm you would need 200 volts! The problem from what I have been lerning from others is the low inductance and that will go up in series as well but if its 100x to low as a single motor then two in series it will be 50x to low!Nuts&Volts said:Don't want to side track the discussion, but would two matched (by resistance and inductance) motors aligned end to end be easier on a single controller? The motors would have pole to pole alignment and one set of halls would be used for timing. Essentially make it one long motor.
-Kyle
