nieles said:
thanks for clearing that up.
but to answer the the "question" from crap.
if we are limiting battery current there will be no performance gained
correct?
Generally that is true, but there are lots of things to consider, what is performance? Is it peak torque, top speed. Changing the winding changes the controllers ability to deliver power at different speeds, that can somewhat be overcome with adjusting gear ratios.
Quite often performance is measured by top speed, a current limit on your battery spesifes a maximum power, maximum power will translate to a maximum speed (the speed at which rolling resistance and drag add up to the power the battery can provide) if the system is geared to get you to that point.
nieles said:
what about if we limit the phase current?
If phase current is the limitation (controller or motor limitation), you probably want to get the motor so that it overheats at the same time as your controller (i.e same current limitations on both). If your controller can deliver 220A continuous, and your motor can handle 380A continuous and it is in delta, you would probably want to change it to wye, and re-gear 1.73x taller. This one is hard to explain, since upon intial calculations you might figure out this:
Imagine a 70V 220A controller, with a 380A continuous rated motor with a 40RPM/V kv in delta. That should spin up to 2800 RPM and deliver 220/380 of its rated continuous torque, I am lazy to calcualte a valid continuous torque, so lets call it 1000 sheep (Sheep is a new unit of torque), so in this configuration it should be delivering 579Sheep of torque. So the max theoretical power of the motor is 1.6 Mega Sheep RPM (power is rotational speed times torque) and the motor shouldn't get too hot since you can't deliver its rated current.
Now with the same 70V 220A controller, switch the motor to WYE, the continuous current rating drops by a factor or 1.73, 380A/1.73 = 220A (convienient eh?). Not so nifty is the kV alo decreases by 1.73 to 23RPM/V which means the 70V controller can get you to 1600 RPM. The good news is that your 220A now delivers the full 1000Sheep of torque. So you now have a motor that can still only deliver 1.6Mega Sheep RPM of power, but gets hot. That seems lame.
So then why aren't all motors designed to have a really high kV so that you can spin them extremely fast and deliver lots of power and not overheat. The answer to that is complicated. I just like to go by the common intuition which is that if everything fails at the same time, it was designed properly. If you have a motor and controller with the same current rating, you probably have the optimal system without going into all the crazy math to figure out why it is the best system.
-ryan
*note I am lazy and not really thinking everything through so there could very well be an error in my logic above.
