I think my BMS tanked and May have brought a cell or two with it.
In January 2017 or so I installed a 12s2p Nissan Leaf pack in my mower. I used the included “Battery Management System SD Technology - SDT14S20A” which was with the kit.
The last couple time I charged it stopped at 48.7 volts or so and it was cold and I really didn’t think much about it. A couple weeks ago I checked and the cells were spread out as shown in the attached. The balancing seemed to flash on for all odd then all even cells which is similar to what I recall long ago except it used to do odd even not all at once. I nievily thought I could plug in the charger and it would do something but it ended up starting to flashing different voltages 1.# or 6.# randomly assigned to cells as the charger started and stopped.
The wiring looks good as it was and terminals are clear of debris.
Does the odd random voltages just mean the BMS is toast? With the large differences now should I individually or at least use a balance charge to bring everything back up?
