dogman dan
1 PW
Definitely hard to identify a bad cell in a parallel string. That's why I suggested 4p sections, connected by a wire you can snip and reconnect easy, so you can identify it down to 4 cells to remove from the pack.
I'd highly recommend building it as modular as possible, so if you need to remove a section you can do it fairly easy. 4P spot welded, 6s welded, Or the same soldered. The idea being that a suspect section can be removed, and replaced with one you have ready to go fairly easily.
Then at your leisure, you can dig into the section to find a bad cell. If you don't have enough cells for spares, build 7P.
Each 4-6 cell section can be tested and passed before final assembly into a huge pack! Especially if you solder, you can set aside any section that might have had a cell ruined in the soldering.
Shitloads of practice, before you start soldering round cells. It must be done very fast from what I hear.
