kristafervale
- Joined
- Apr 2, 2015
- Messages
- 16
Hello everyone,
First let me just say thank you to this amazing community for all the valuable information you all have collectively provided! I've done a lot of research in the past few weeks and over and over again the best information has come from reading all the really great posts here!
I'm in the process of putting together what I hope will be a reliable daily commuter bike for use in the San Francisco Bay area, which means quite a few major hill climbs every day. The main considerations for this first bike were cost and reliability not max speed etc.
For the Motor / Controller I went with this inexpensive ebay sale:
http://www.ebay.com/itm/221691273393?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I can't find any good information on what type of controller it uses, what kind of power the motor pulls at full throttle etc so any help in learning how I may go about figuring that out would be greatly appreciated!
Since I'm on a budget I decided to try and take on the task of building my own 12s8p battery pack out of some bulk cells I purchased from an ES member.
Here is a link to the spec sheet they sent me about the cells.
https://drive.google.com/file/d/0Bx2c0o3VP6lES0RKeFl2XzV6ZDRsMnozNUJ3SlY3U2pteEpV/view?usp=sharing
I plan on creating 12 8p packs out of these and then wiring them in series for the max 12s8p pack. I would like to balance charge these using an iMax B6AC v2 which I already had.
http://www.amazon.com/Genuine-SKYRC...8&qid=1429029610&sr=8-1&keywords=imax+b6ac+v2
I'm hoping to have as an end result something similar to what ES member patrick mahoney described in his post:
http://endless-sphere.com/forums/viewtopic.php?t=826
But I've hit a couple of questions now that I thought I would post here in hopes that they aren't too N00Bish. I've done some searching but can't seem to find the right information and with the risk involved hoped you all may be able to steer me in the right direction.
1.) Is going with a 12s8p setup the best way to go about making this pack? Is there some more optimal configuration I should consider?
2.) When creating these packs if I use a the above charger and a parallel charging board would there be any benefit to wiring anything in series during charging or would it be better to just charge the individual 8p packs 6 at a time?
3.) should each of the 12 8p packs have a BMS or should the entire 12s8p pack have a single BMS and am I right that I would only use that when riding, i.e. not when charging?
4.) if I do go with 12s8p my plan is to hard wire (soldier or spot weld) the 8p packs individually and then use wiring harnesses to create the discharge / charge wiring separately. I THINK that means that I just need a single JST connector on each 8p pack and then something to make 6s 16p configuration for charging is that right?
5.) Is there a learning resource, other than doing more searching here on the boards that anyone can point me to? I'd like to fully understand all the ins and outs of battery management and pack creation but the information does seem to be a bit scattered and in some cases contradictory. For example a lot of advice seems to be to make more series packs and wire those in parallel and vice versa lots of parallel packs then wired in series. Is there a gold standard or "right way" to do it?
Again, I apologize if this information is all out there already and I just failed in my attempts at research, even just links to existing information is greatly appreciated! Thanks!
