150 A Wattmeter and power analyzer value question
newb123
I had a problem when gunning my throttle or from a dead stop of my bike controller or BMS, cutting off. 42 volt 20S 400 watt motor brushless controller
So I purchased this 150A Wattmeter with Amps Voltage etc
The Amp Voltage and Watt values are self explanatory, but the other values, I can understand the Chinese/English in the manual, it seems there is no description at all for the values. When gunning the throttle, I saw the Amps go all the way to 20 but normal ride at about 10
The value 31.53 Vm...what is this?
The value 00:11Te...no idea
21.06 Ap...no idea
and 21.0 WH I guess its Watt Hours
how can I use these values to troubleshoot my issue? Any help, greatly appreciated
Here are my guesses :)
Voltage Minimum, what the voltage drops to when you are at max amps (20 amps)?
Time since powered up?
21.06 Ap...no idea
Max Amps?
Correct
the Vm one is probably the one you should be looking at. Means your pack dropped to 31.5V at some point, which is most likely below the low voltage cutoff for either BMS or controller. Possibly the most useful function of these meters, especially for troubleshooting these type of problems.
Thanks for that...does the Vm = sag? so this would mean, my batteries are at the end of their use? They have been charged/cycled too many times? I got them for free, they charge up to 42 V but off the charger, they will cut off if I gun it or start from a dead stop
Some sag at high C-rate is perfectly normal even brand new top-notch cells.
As they wear, will see it increase.
Capacity testing is the real indicator of SoH, 70-75% should be EoL, even 80% to be conservative.
so the conclusion would be at 31 volts, the BMS or Controller, is dropping out?
newb123 said:
42 volt 20S
If you have a 20s battery that is only 42v, it's destroyed, at only about 2.1v per cell. You will have to replace the battery as it is no longer safe to recharge. (assuming it's "LiIon" rather than some variety of LiTi) About 60v would be the minimum I'd let a 20s battery get down to.
If it's actually 36v battery, 42v fully charged, then it is 10s, not 20s, for a typical LiIon battery. In this case, 31v-32v is a fair enough shutdown point for your controller. 28-30v for the BMS LVC.
Minimum voltage, what your battery sagged down to under the 21.06A peak load.
Elapsed Time. Presumably HH:MM so 11 minutes of operation.
21.06 Ap...no idea
Peak Amps, the maximum current during the ride.
Yes.
The Vm tells you how much voltage sag you had. If the system stopped operating, then the Vm is below the LVC, low voltage cutoff, of the controller.
If it had been teh LVC of the battery, it would have cleared the data in the wattmeter too, and that would have gone blank/turned off along wiht the motor.
The Ap tells you how much current the controller pulled from the battery under load. If the system stopped operating under that load, then the current draw is too high for the battery to handle.
This means eitehr the battery itself has a problem (bad cell, unbalanced, etc), or it's design and parts are incapable of handling the current draw.
Thanks very much for the informative reply
I posted the wrong spec; by 20S, I mean 2 strings of 10 cells in series for a total of 20 cells,
the (2) strings are paralleled. Using the 18650 cells so charged them to 4.2 volts each so the BMS will balance them, seems some are unbalanced until I do that. Off the charger Im at 42 volts
This controller is very old, I got it when Ebikes were using lead acids. Im suspecting now that 40+ volts, there is a High Voltage Cutoff, because in those days, I guess 42 volts was an overcharge?
So, when Im at 40+ volts, the controller cuts out. as soon as I get below 37 there is no more cut out, even on steep runs or from a dead stop
If this is the case (there is a HVC on this controller) Is there a way to hack the controller to get a higher voltage input? Im guessing the HVC on this model is around 38 or so.
I have seen current shunt mods and have ID that trace. Dont know if that will give me more voltage ceiling or not
When the controller cuts off (Im still strongly feeling its the controller, not the BMS since the BMS is rated for 48 volts with different sense wire harness) Im usually at 40+ volts and Voltsm on the wattmeter says 5 volts, after cutoff.
Thanks for the details on the wattmeter specs, that clears allot of that up nicely. For the watthour rating, does that help estimate range?
Im seeing max amps at 20 on hill climbs, dead stop starts at about 9 amps.
That's 10series, 2parallel, or 10s2p.
5A continuous per cell (10A / 2p) isn't much for some cells, while for others it's extreme. You'd have to look up the specs for your specific cell brand and model to find out what they are supposed to be capable of, and look at the discharge curves they publish, to see what voltage sag there *should* be, vs what you actually see.
If they are used cells, then even those specs aren't valid, and they likely can't take even as much current draw as the specs say.
If they are always unbalanced after every use, then either they're being pushed harder than they're capable of, or some of them have problems. (or both). Their internal resistance, capacity, etc., are not all the same.
To find out which, you need monitor the voltage on each cell while the load is applied. You don't have to test them all at the same time, but just one at a time, starting from the same conditions each time, and doing the same load test each time.
YOu can also monitor them during charging, and those with higher voltage while current is flowing are the problem, just like the ones with lower voltage during discharging are the problem. (they should be the same cells).
That doesn't make sense, unless it was meant to be used on a 24v system (two 12v SLA batteries). In which case it probably has HVC protection to keep from destroying the electronics. You don't want to bypass that, or use it at a higher voltage than it was designed for, unless you have made sure all the parts in it are designed to work at the higher voltage, plus a margin for safety.
No. The shunt doesn't monitor voltage, just current. Modifying the shunt makes the controller unable to accurately monitor current, so it can't safely limit current to protect itself or your system. It's easily possible to damage or destroy a controller (or a battery, or motor) by doing this, so keep that in mind before you do it.
If the BMS was shutting off, the entire system would power off, including the wattmeter, because no current could flow from the battery to run anything, and voltage would drop extremely (to zero if any load, like the controller, was still attached).
I dont know how to monitor each cell, while connected in the pack, under load, so I will check them during charging
Yes, but it happens every time. Once I get to 38 or 37, no issue, except, there is some initial jitter from the motor, like the halls are jumpy, but once up to speed, all smooth, as far as a trapazoid wave controller goes. This original controller was used with the same motor and (3) 12 volt lead acids in series for 36V
The Wattmeter does shut off sometimes during the cut out situation (@ 40+ volts), so maybe it is the BMS.
So, could a BMS be shutting down, at 40+ volts for some reason, like one cell completely off? I measured off the charger, all cells balanced at 4.2V. These cells came out of a panasonic set, so sure they can handle the discharge current. I will recheck the spec sheet.
Then something else is going on. Either the controller has a problem, or there is a connection problem somewhere, or the battery has a problem.
In at least one of your previous threads you had a problem with the system/battery cutting out during acceleration, which indicates a problem with the battery being unable to handle the current.
If you are using a different battery now, but having the same problem, the new battery could be bad too, or could be connection or electronics problem anywhere between cells and motor.
If it's the same battery pack, it is likely the same problem.
I wish it was that simple....but just because they are a particular brand doesn't have anything to do with how much discharge current they can handle. Each brand has many models of cell, some of which have higher capacity but lower current capability, some of which have higher current capability but lower capacity, and some of which are in between.
It is specific to the model of cell, and remember the spec sheet is only fully valid for brand new cells.
If yours are used or old, then they are no longer capable of the spec sheet values. How much less capable depends on their age and what they've been thru, which you can't really know if you're not the original user. You'd have to do the voltage tests during charge and discharge to find out what they're still capable of, in reference to the spec sheet values.
If you had a tester that could give you the internal resistance of each cell, then that could be compared to the spec sheet, to give an idea of how far from the original specs they are, for current delivery ability. Wouldn't tell you the capacity; that's a separate test, but it would help determine how hard you can still push them.
ok I will recheck the connections but this morning, same issue, wattmeter cuts off (no display) if I am over 40+ volts, reset, does the same until I get down to 37 or so
It is all a step-by-step deduction process to figure out what is wrong.
Something is definitely wrong if the wattmeter *and* controller shuts off when you are simply *over* a certain voltage:
The BMS must be shutting power off to it's output.
There's no reason for a BMS to shut off its output when a voltage is *above* a certain point, only when it is *below* a certain point.
If it is shutting off simply because the voltage is above that point, it's probably defective.
If it is shutting off because the voltage is above that point *and* current is over a certain level, but *not* when voltage is *below* that point *and* current is over a certain level, then that' still wierd, and may still have a BMS problem.
If it is shutting off because the current is over a certain level regardless of voltage, then it's probably a cell or cells dropping below the BMS LVC point.
You'll have to test to see what's actually happening, by measuring each cell's voltage during the event(s) in question, to see if it's the cells.
If it's not one of the cells, then maybe it's the BMS itself. That you can test for by connecting the main + and - of the cells (rather than the BMS) to the controller, and do the same thing as before, and see if it still shuts down.
If not, then something about the BMS is causing it...whether it's a defect or a problem in wiring or a setting (if it's programmable).
Thats the next isolation test I will do. Was doing a hill climb, then it stalled out again (38 volts+) Im guessing the BMS is sensing some over current, because I had a brake pad drag, that was causing resistance, un hooked the caliper and seemed to go easier.
doesnt seem to be doing that, under 37 volts
its not the controller, I disconnected the BMS
Now need to find out why it was the BMS
As I can monitor total voltage on the Wattmeter, perhaps just use the BMS to balance charge?
Its only purpose during riding is to cutout if a cell goes to for ex. 2 volts or overcurrent?
UPDATE
Ok I tested all cells after a short ride, all balanced at 4.13 volts
So, for some reason the BMS was cutting out due to over current, I guess. Will ride without it, monitoring the wattmeter for now and use the BMS for charging only
the BMS Im using is rated at 42 volts (not 48, as mistakenly previously posted) but, Im using the 36 volt sense wire harness. Wondering if, that is the problem. Once I charge to 42 volts, the BMS, using the 36volt sense wire option harness, is reading an over discharge of 42 and cutting out? I has a over discharge protection feature
Specification:
10 string 36V 37V 42V lithium battery power protection board
Overcharge, over discharge, over current and short circuit protection
Split-mouth 35A discharge current, with balance circuit
With heat sink and 300mm 11-pin cable
Size: approx. 69 x 51.5 x 10mm
Parameters: (10 series of lithium-ion battery)
Package Included: 1pc x 10S 35A Lithium Battery BMS PCB
Potentially dangerous, as if a cell goes below the safe level, it can be damaged. If it's unbalanced badly enough compared to others, you can actually run it to zero or even reverse it.
Any of those can cause damage enough to make it a fire risk. But you won't know if it's even happened, unless you measure each cell when the bike's performance changes, or after you stop.
Yes, it's purpose is to keep you from damaging cells, and potentially having a fire during charge or discharge, etc.
So I don't recommend running without the BMS.
If it's current limit is what is stopping you, then it is protecting the cells from being damaged by drawing more current from them than they can handle, and overheating and/or dropping too low in voltage.
(assuming that the BMS's current limit is set / designed to what the cells themselves are actually capable of. If it is already higher than what they can handle, then it's already possible to damage them even with the BMS, and much more likely without it).
Since the BMS is already allowing at least 35A, which means over 17A per cell, then if it's cutting off because of the current limit, it means your controller is drawing more than that already.
So if you run without the BMS, you'll draw even more than 17A per cell, and I doubt that the cells are even designed to handle that much current when they are in brand new condition, which, if yours are used, are not.
If you draw too much current thru the cells, they heat up, and can be damaged, creating a fire risk if they get hot enough. (the core of the cells will heat up faster than the outside, so they can get pretty hot pretty quickly before you know there's a problem if the current is high enough vs what they can handle)
With used cells, they're often different enough in capability from each other to be different internal resistances, whcih means they heat up at different rates, so you'd ahve to monitor each cell's temperature to know if something is going wrong. Alternately, if you can test each cell's internal resistance (requires a tester for this; some RC chargers can do it, but I don't know how accurate they are), and then use a sensor(s) on just the cell(s) with the highest resistance, as those will heat up the most.
That just tells you they're at the same voltage when at rest. It doesn't tell you anything useful about why the problem is happening.
You must test while current is flowing at the rates you normally use it at, while charging, and while discharging, to find out if there is a problem with the cells under those conditions, causing your problem.
42v is the full voltage of a 36v (10s) pack.
If you are using 10 cells in series, then that is correct.
If you are not using 10 cells in series, then you need either a different BMS or to wire it up per it's instructions for however many cells you do have.
42v is not over discharged. It is the full voltage of a 36v pack.
42v would be over discharged for a 60v or 72v pack, for instance, because those have enough cells in series that 42v divided by that number of cells would be less than the damage-level voltage of those cells.
If it was an over *charge* problem, then it would not continue to charge the pack, cutting off the charge port.
If the charge port is the same as the discharge port, it would cut off both, and you could not use it on the bike at all--the bike would get no power and would not run at all, and your wattmeter would not work either.
if the wattmeter is showing 20 Amps peak on a hill, about 9 amps and full throttle flat landscape
how can I ever get 17 Amps per cell? it seems the cells would be too hot too touch at that current. Currently, they are warm to the touch after a ride, not burning
Then that means the BMS can't be cutting out due to overcurrent, if it's limit is 35A, so overcurrent isn't your problem either.
You can't, if the system isn't drawing enough to make the 35A BMS shutdown from overcurrent.
Keep in mind that anything I tell you is deduced from whatever you tell us.
If you say the BMS is shutting down from overcurrent, and you say the BMS current limit is 35A, then I must conclude that means the system must be drawing more than 35A, or 17A per cell in a 2p pack.
But then you say the wattmeter is indicating 20A or less maximum, so assuming the wattmeter is even close to accurate, then I must conclude that means the BMS cannot be shutting down from overcurrent, because it's limit of 35A is not being exceeded.
Does the controller label show what it's current limit is supposed to be? (some old controllers don't even monitor current, so they don't limit it either).
As I said before, it is a matter of deducing what is wrong from the results you get when testing.
If the tests give you certain results, then certain answers come automatically from those results plus other information you already have.
If the answers don't make sense, then some of the information you already have (like part specifications, etc) is wrong, or some of the tests arent' giving accurate results.
Further tests can be done, on each part, to find out what is really happening, and it can be frustrating.
But if you keep all your stuff in just one thread, it will help us help you figure things out.
If you make new threads for each part of testing your problem, then all of the information is not in one place, so anyone replying to the new thread that hasn't seen the old ones doesn't even know any of the previous stuff. And anyone else (including me) replying would have to look up your other threads to find the info, and maybe miss things, so either give you incorrect answers, suggest wrong tests, draw wrong conclusions, suggest tests you've already done, repeat explanations you've already gotten, etc.
ok understood, and thanks
I just know at this point, I bypassed the BMS, watt meter shows the same conditions, about 10 amps average, 20 on a steep climb, and there is now, no cut out
cells are unbalanced after a long ride
they balance at 4.2 each with BMS charging
warm too touch, after long ride, nothing hot
Then that means the BMS is causing the cutout, but you still don't know why.
This means the cells are not all the same capability.
This probably means one of them is the reason the BMS is cutting out.
It is most likely that hte ones with the lowest voltage after a ride are the problematic ones, but that isn't always the case.
A "guesstimate" test is to mark each cell with it's voltage at that point, and sort them in a line from best (highest voltage) to worst (lowest voltage) and then make parallel pairs out of the best cell and the worst cell, starting at the ends of the line and moving to the middle.
Then reconnect it all up as the same 10s2p pack but with the cells in that pairing instead of the present probably-random pairing.
Then each group will be closer to being the same capability as each other, and less likely to cause a cutout.
To find out which one(s) for certain, you'd have to do the test of each cells' voltage during charge / discharge, under the same conditions for each cell, so you can compare them, and find out which are causing the cutout (if any).
so this means, using the DMM and just go cell by cell, checking for the lows and highs during a charge cycle (for ex. 2 hours) ?
also from the information on the wattmeter display, can I get an accurate indication of my watt rating of motor (I forgot it, its very old) and how much range I have? I hacked a battery pack so this is not the original Amp hour rating of the pack.
he gives instuctions here but, thats for if you know the amp hour rating of your pack
https://www.electricbike.com/watt-hours/
More or less, yes. There's a bunch of threads about repairing and/or testing batteries that give you details on the process.
It won't tell you how it behaves during discharge, but the same cells would likely have problems in either case, so it'll still point you in the right direction.
It won't tell you anything about ratings or specifications of anything. That would have to come from manufacturer data for the part in question. (sellers often give such ratings too, but theirs cant' be trusted as they are too-often made up or exaggerated so they'll sell more).
It will only show you the max watts (Wp) that the system actually draws in use, and that is limited by the controller's current limit and how much voltage sag your battery pack has under that load.
Since the wattmeter gives you the Wh total of the pack, (and the Ah), then you can get the capacity it has, by riding till it shuts down, and keeping track of that reading constantly, so you know what it was just before it shuts down (since the wattmeter probably doesn't keep its' data when it loses power).
But to get the range of your pack, you can simply ride it until it shuts down and then you know what it is under those real conditions, and then always ride planning for at least 10-20% *less* than that distance.
(you just need a bicycle computer or something similar that has an odometer on it, since the wattmeter does not have any way to measure distance)
That's because if you always ride to BMS shutdown, it's going to be much harder on your cells than if you dont' run them all the way down every time. They will have many fewer charge/discharge cycles available (especially since they're already used to an extent you don't know). Plus, it gives you potentially that much "extra" for detours or headwinds, etc.
And as the pack wears further, you'll get less and less range from it, so planning so it doesn't require the full capacity in teh first place means that it will still do what you need it to for at least a little while, instead of very quickly becoming unable to do it as it ages further.
