Philosopher
I just bought a Brushless motor Lithium (LiFePO4) 1500w 48v 20ah standing kick scooter. It arrived in the mail and I took some pics as I un-boxed it.
I also have some questions and comments about its performance and equipment that I will discuss in the next post.
Photo captions are Above the pics.
box arrives 1
box arrives 2
opening box
opening box
emptying box
looks like a scooter.
Front Wheel these are knobbier than other scooter tires I have seen. The rims are 7" in diameter and the tires are 11.5" in diameter (just barely).
Rear wheel.
Metal Battery Box.
Scooter's batter area - Under the deck
The controller is loose in the housing.
Ah... there is double sided tape that is supposed to hold it in place.....
Factory markings. Note, there are no ports in the housing for any sort of data plug.
Inside the controller 1
Inside the contrller 2
Inside the controller 3
Inside the controller 4
Inside the controller 5
Inside the controller 6
Inside the metal battery box.
Note all the empty space in there.
Battery measurements. I am concerned that these are the EXACT SAME physical measurements of my other scooter's smaller 48v 12ah battery. This is supposed to be 1500w 28v 20ah.
Totally useless instructions that are also in French. but they would be utterly useless in any any language. all fluff. no tech specs, wiring diagrams or actual usable data. Half of the pics are of a totally different model. Meh.
Included Tool Kit. Not to fancy, but definitely better than nothing. Has a nice, super cheap little carry bag too.
Motor's measurements: 4 7/8" long and about 4 3/16" in diameter. It does not fit very snugly in the frame.
The motor stampings. These are the ONLY markings on the motor. It starts "48v 1500w" not sure what the other numbers mean.
The wires coming from the motor, as seen below the deck, near the controller.
The rear tail light on. It and the headlight can be turned off.
The rear tail light with brakes activated and "brake light" illuminated. Nice feature.
Handle bar controls with 3 LED battery indicator lights and a "turbo button" that gives the scooter about 2/3 to 1/2 power for increased economy.
To be continued.
-Phil
box arrives 1
box arrives 2
opening box
opening box
emptying box
Rear wheel.
Metal Battery Box.
To be continued.
-Phil
