Ianhill
- Joined
- Sep 25, 2015
- Messages
- 2,919
When the battery box sits inside the frame theres a 2mm gap clearance to the bars that protect it from ground out, I've decided to fit 1.5mm alloy plate to the battery box so i can get some outside cooling for the bms, shunt and antispark while leaving enough space to get the box back in.
There's no room for the battery wires, throttle and brake to pass through the battery box to the controller so im going to have to work a solution with a bit of small conduit, everything is tightly packed and i dont want it to be a mess all lose and enclosed no heat path just waiting to catch fire so theres abit more work to be done.
I'm waiting on a flipsky watercooled antispark, I'm going to convert to aircooled and run it way less than rated, then i can test see how everything works and then fineese.
