Greetings,
Firstlly wnated to tell you that I am new to this forum and find it very good and informative!!
Curently I am designing on a battery pack for the conversion of an lawn tractor.
I want to use 18650 battery types and be able to interchange individual battery if needed or for whatever reason.
The most, if no all, battery packs I have seen so far were with soldered or spot welded battery contacts to the busbar.
Could I use a button, leaf spring or coil cpring battery contacts?
What would be the con for such battery contacts?
Is the contact resistance higher than with soldered and spot welded battery contacts?
Thank you very much in advance for your answers!
Regards,
Falco
Regards,
Falco
