It might be possible to nickel plate the ends. I’m not sure how much current it takes or how long but I think it’s pretty easy. For sure bare steel will get rusty fast.
SafeDiscDancing said:Has anyone tried laying the cells flat (and in series) rather than upright before compression?
Seems to me that if the cells are flat and you hit bumps which are mostly up and down movements that the weight of the battery would be directed away from the contacts towards the sides of the cell.
This would allow a light pressure from end to end since you aren't worried about any bouncing effect.
In the case of parallel cells you could have copper strips with little dimples on both sides (not sure how) which could then be the attachment point for balancing wires.
A set of four parallel cells stacked 2x2 could then be inserted into a square tube made of plastic or fiberglass.
Then you just have springs on each end to bind up the series. Maybe each series is six cells. Two of these is 12S.
This project is far along and looks good, but it's just a different perspective on the problem.
APL said:Somehow missed the fact that I need a charger for this pack, focused on too many other things I guess. :?
Looked around and found these guys that look OK,.. reviews seem good. 60v 3A for $60.
Any enlightenments? Just don't want to buy a lemon.
Yes as you say half that is much healthier but sometimes we are in a rush. 2C is even OK so long as only once in a while, with healthy well balanced cells, and OTP.APL said:Since I have an 11p pack at roughly 29ah,1C would be 29A? That sounds a bit high,.. I thought that 5A was pushing it!
