ridethelightning
- Joined
- Jul 21, 2013
- Messages
- 2,010
tomjasz said:What would you use as gasket material, or is there a ready made source?999zip999 said:Are you using any protection on the pos. end to keep that solder wick from shorting on the neg. Case ? Like a gasket ?
i used suade leather as gasket on my lg pack. abrasion resistant,heat resistant,soft/plyable, easy to cut to shape, hot glues well.
the cells own protection gasket melts through in a split second to the touch of a soldering iron or hot metal, as i found out when soldering on the pos end=LIGHTNING!
card could be another good material.
the other thing about having a gasket is i think it protects the cells from excess heat if soldering bus bars across the spotwelded tabs
