chaka
After having seen countless discussions, graphs and lectures and my own testing I have come to the conclusion that these cells, no matter what their rating, will degrade by as much as 40% after only 200 charge/discharge cycles when used in a high discharge environment. It has been shown that you can increase cycle life by 400% or more simply by discharging at 1C or less and charging at 0.5C. Some cells can go 2000 cycles at this rate and still retain 80% of their original capacity.
What this means in regards to cost and efficiency. Cost is an easy one to figure, not only are high discharge cells double the cost they also will have to be replaced at a much higher rate when discharged heavily. Usable capacity is another factor of cost, when a cell is discharged at 1C or lower it has more usable capacity due to a lower voltage sag giving you a higher return on your investment.
Discharging at 1C or less also flattens the discharge curve giving you a higher average voltage and minimal initial voltage sag.
Charging at 0.5C or less may seem tedious until you realize this means charging at 350watts in a 700wh pack. Not so tedious now is it? This shows that we can charge our packs safely at high wattage with the use of a high capacity pack.
The only industry I have seen that is paying close attention to these characteristics are auto manufactures, it wouldn't be very profitable for them if they had to replace packs under warranty after only 1 or 2 years of service. On the other hand, if you are in the business of selling batteries, it is more profitable to have consumers replace batteries frequently if there is no long term warranty to worry about.
One reoccurring discussion is the use of easily swappable batteries to gain more range. It works but why not use all the batteries at once and have them work together? This will extend the overall range and cycle life of your investment.
The initial investment in a large capacity pack may seem a bit high at first but in the end it will cost you nearly 10x less than a high discharge low capacity pack. This factor is further increased by the fact that you now have more lower cost options to choose from since you are no longer dependent on expensive high discharge cells.
