Simple818 said:I ride mostly street and I notice that when I lean into turns with the 26-2.1 front tire it gets a little skidding for lack of a better word. People keep on telling me that I need to go 17" up front as well for best handling but my pedal clearance I think will become an issue. So I'm thinking of using a 24-2.4 maxis holy roller to match the tread pattern and give me a little lift up failing but not too much
Simple818 said:Does my bike wheelie easily? Oh yeah. I really have to ease into the throttle. But.... I love it. So a better, perhaps wider front tire will help? Along with a more forward sitting position?. Ideally, I would like to go to a 19"Moto ip front but this bike really hit the wallet already. That's why I was thinking a 24" wide bike wheel up front would be a good compromise.
captain387 said:Well I have wrecked rim #2 which was an Alex DM24, Pinch flat on the asphalt edge of a depressed catch basin. The rim also dented pretty bad.
I had traffic along side of me so I was unable to avoid it, time to switch to the MC rim and tire.
Where is the best place to order a 19" MC rim and tire and possibly spokes, (If I do not find a threader for my existing spokes).
I am located in Kingston Ontario, Canada. I am assuming the answer with be Holmes, but maybe someone has a rim down the road from me.
99% of my riding is on the road,
I searched through a pile of tire companies, and this thread but I was unable to find a 19" street tire that resembled the street tires that are available for the 17" rims.
My frame is a 04 Norco Atomik, the widest possible tire that would fit my swing arm would be 3", my caliper is showing 3.1" but a 2.75 or 2.5 would be ideal.
Thanks
Jeremy
Simple818 said:Here is my current setup.
usertogo said:I am sorry for not having taken the time to go through 39 pages of fun discussion about the subject, so I don't know if it has been discussed here before, it certainly isn't an easy subject to google, but I found one forum thread about it in German:
at http://www.tretharley.de/phpbb/viewtopic.php?f=2&t=7707Atze und Pit haben z.B 16" Motorradreifen auf 20" Fahrradfelgen.
Und 19" Reifen passen auf ne 24" Felge.
Und 21" Reifen auf 26" Felgen,
The issue is the front wheels of my trike are 20" bicycle rims, so they have an outer diameter of just under 42cm (rim). There is a small motorcycle type we call Moped with tyres that are measured differently than bicycle tires. I wonder if anybody can confirm, that the 2 3/4 x 16 Tires ( http://www.ebay.de/itm/261830361408 ) will indeed fit on said 20" trike rim?
Thanks
Tobias
Rix said:Simple818 said:Here is my current setup.
Just occurred to me, your front end washing may also be from your forks flexing laterally. Do you have a dual crown fork or a heavier duty single crown free ride fork you can swap out and try? This may be the solution.
Rix said:captain387 said:Well I have wrecked rim #2 which was an Alex DM24, Pinch flat on the asphalt edge of a depressed catch basin. The rim also dented pretty bad.
Thanks
Jeremy
Your best option would be Holmes 19x1.6 rim or Prowheel Racing 19x1.4 TTR 125L Yamaha Playbike rim. Since clearance is an issue the best tire for your mount would be a Vee Rubber VRM 2.75-19 which is a tad narrower than 2.75 wide when mounted on a 19x1.4 rim.
wendell said:I've got 3.15 inches on 1.4 rim
[attachment=-1]uploadfromtaptalk1433732051746.jpg[/attachment]wendell said:wendell said:I've got 3.15 inches on 1.4 rim
macribs said:I wonder what tire/rim combination this is? Tried to ask in the Qulbix thread but no reply. Tire seems aggressive, almost like a motox tire. Some real knobs on there. Should like to know brand and dimension.
Rix said:.. wish that Denzel Ebike guy had posted all his prices and followed the policies of ES, he had a very promising 24x3.00 ebike tire.
Me, too. But he stopped even answering messages asking for prices, and then stopped even coming to the site. I guess it was too much trouble for him to sell stuff if he had to tell us how much it cost.Rix said:I wish that Denzel Ebike guy had posted all his prices and followed the policies of ES, he had a very promising 24x3.00 ebike tire.
nutspecial said:Hi guys, I've been running sunrhino 26" on my build and they're olding up ok. I have broke a few spoke nipples when trailbazing though. I guess if something has gotta break when you crash in a pile of driftwood, that would be better than destroying spokes or pulling nipples from the rim.
The wheels are hold tru to moderate riding and power /lightweight, even with a heavy redish on the rear.
My biggest complaint with bike wheels is the darn tires. They are wearing so fast. 100 miles and half tread, and I only really giverhell off the asphalt.
*Is there a hd mx'ish tire for a 24" (new build size) bike rim? or a 26" (for the old build)? I've used kenda and duro razorback bike tires, and both don't have enough meat/ too soft.
-If I have to lose the bike rim the new build will use a 17" moto rim/tire for the rear.
*For my reference, what are the approx weight differences between a bike and mx wheel/tire. I saw some weights listed, and will guess on average 19"/26" it'd be 5lb/10lb respectively?
*Best source for 17" rim, (I'm thinking this, so angles are proper for bike hub?)
http://www.amazon.com/Pro-Wheel-Front-Rim-Position-17-0HKBK/dp/B000GZP4XM/ref=sr_1_6?ie=UTF8&qid=1433948205&sr=8-6&keywords=17+mx+rim
spokes (heaviest that fit the rim and hub properly)
and xt bike hub? (Prices for raw new hubs are a little high on amazon)
Is there someone that builds 'em?
*I'm not against building myself; and if so what is the budget spoke roller of choice? And the builders choice of stock spokes? Edit// looks like there's not much need to make spokes when they can be bought here? http://holmeshobbies.com/Sapim-Stainless-Custom-Spokes.html
On prowheel to xt hub, 13/14 gauge spokes, and 13g 7.75g nip or 13g 9.5m nip?
Thanks!!!!
