Rix
100 TW
Mammalian04 said:Offroader said:I actually have a 17x1.6 Holmes rim (3rd 17x1.6 rim) that is slightly warped and junk now, bent in and can't be trued, after breaking like 11 or 13 12 gauge spokes in a nice hit.
Maybe I'll drill that out as a test to see how much weight I can reduce on that to see if it is worth it to drill out my good rims.
Rix: you shaved 7 oz on a 1.4 rim, but a 1.6 rim is much heavier and should be easier to shave away the weight.
Does anyone know if I can get away with drilling some holes in the sides of the rim also?
It would seem that the sides would be important for both bead and strength.
In theory, I think you could, unlike the slighty narrower 1.4 wide rim, a guy could ovalize the drill hole and go wider, I am guessing you can't go bigger than 7/8 as you need to place those holes between the spoke holes, but ovalizing those holes the width of the rim could take out more material.
