999zip999
100 TW
Maybe a carjack scissors Style.
litespeed said:Looks pretty peppy!
Very nice.
Tom
Thats a small 19" tire 2.0, I don't I have ever seen one that small in real life.999zip999 said:Looking for a scrambler 19in 2.0 can only fine a cheap chen.
999zip999 said:Yes i have seen just the cheng 2.0 looks flimsy. So I guess my next choice is 19 inch X 2.25. I live in Southern California what's a good moped tire supplier for 19 inch 2.25 ? I guess I just don't know how to look for it
19 inch 2.25
Jimboyr6 said:https://www.ebay.co.uk/itm/270646414646
2 ply as well
macribs said:Running tubeless is fine, no problem. You will have to modify as you said.
Glue, silicon or tape will work. If you trust your wheel truing skills and are sure you will not need to retighten spokes any day soon a dab of glue (ie sikaflex) in each spoke hole and then a round of fiber strengthen gaffa tape and you are all good and ready. You can even ride low tire pressure.
If you get a flat running tubeless it is a 2 minute fix, with time left for a smoke 8)
bionicdan said:Could I just run a tubeless tyre with a tube? I thought I read the beads can be different. Might have misread it
I just really like the kenda profile (looks the most rear like even though its a front). But it says tubeless and didnt want to order it incase I was making an obvious mc tyre newbie error
Rix said:bionicdan said:Could I just run a tubeless tyre with a tube? I thought I read the beads can be different. Might have misread it
Thats not a problem running a tubless tire with a tube. Done it for years on my Dual Sport MC.
Mammalian04 said:If you have the tire off for a new tube, put two tubes back in. One in each hole of the moto rim valve holes (differentiate the two so you don't fill the wrong one). Then if you get a puncture, you can just inflate the other (if both weren't punctured). I plan on doing this next time I have my tires off. I stole this idea a while back from either Rix or Chalo I think.
