Offroader said:Thick tubes are really a waste for an ebike. Really, even on bicycles most people recommend not using the heavy thorn resistant tubes.
My 3.00x17 tubes weigh only 1 lbs. Those thicker tubes weigh 2 or 3 lbs.
Offroader said:Why would I need less air with a winder rim?
I range my 3" tire from 11 to 14 psi, I can easily go lower without any issues.
If I went with a 1.4" rim I don't see any reason why it would be that much different and I could still easily use 11-14 psi, maybe even 8 psi.
I didn't think any of you guys even used psi in the 10-15 psi range.
Merlin said:Offroader said:Why would I need less air with a winder rim?
not many run 3" tires.
and no, you dont NEED less air...you CAN.
with an 1.4" Rim and just 10psi your tire may jump of your rim on fast corners.
theres no side stability using a 3" tire on a 1.4" rim.
edit:
thats equal to FAT BIKES with 80 or 100mm Rims can ride with just 6PSI on 4" Wide Tires.
a 4" Fatbike Tire will also fit a 40mm Bicycle rim. But with only 6-7PSI the tire will jump of the rim. (definitly!)
Merlin said:thats true rix....
what i want to say:
if you run a 3" shinko with 10psi offroad, it is superb riding.
and if we talk about 1,6" and 1,4" Rims i dont think it matters.
but on street i wouldnt ride with such low psi on a 1.4" rim. comparing to trial bikes riding SR241 with just 4PSI (and no need for cornering force) on 1.85 and 2.15" Rims my old BETA instruction manual say also that i have to "minimum tripple"(!) the psi within street use.
Chalo said:If you have a bicycle tire on the rear, you can do a Dutch style repair. Dismount one side of the tire, find the hole in the tube and patch it, then remount the tire. The wheel doesn't have to come off at all.
Car and truck tires are pretty strong, too, but can still get flats for a number of reasons.BCTECH said:I thought MC tire/tube was pretty strong so I didn't carry a spare tube/pump with me.
amberwolf said:Car and truck tires are pretty strong, too, but can still get flats for a number of reasons.BCTECH said:I thought MC tire/tube was pretty strong so I didn't carry a spare tube/pump with me.
What caused your flat?
See this thread:
https://endless-sphere.com/forums/viewtopic.php?f=3&t=82771
for some active recent discussion of causes and solutions.
Offroader said:Chalo said:If you have a bicycle tire on the rear, you can do a Dutch style repair. Dismount one side of the tire, find the hole in the tube and patch it, then remount the tire. The wheel doesn't have to come off at all.
Yeah that is how I do mine with both MC and bicycle tire, but the issue is you need 3 heavy tire irons to do that with a MC tire. If you use rim protectors also, you need to carry those or you will scratch up your rim.
BCTECH said:Offroader said:Chalo said:If you have a bicycle tire on the rear, you can do a Dutch style repair. Dismount one side of the tire, find the hole in the tube and patch it, then remount the tire. The wheel doesn't have to come off at all.
after done some research, this looks like can solve the problem
http://www.tireballs.com/pages/shop
anyone use that before?
Offroader said:You dismount one side and pull the whole tube out so you can inspect it and find the hole.
Those CO2 kits weigh like 16 grams. You're probably looking at like 50 -70 grams for patch kit, co2, 2 plastic tire levers. Just tape it under your rear seat.
https://www.amazon.com/Genuine-Innovations-G2673-Chuck-Inflator/dp/B003BMDI9E/ref=cm_cr_arp_d_pl_foot_top?ie=UTF8
You have bad luck because I've never got a flat yet on my front tire that left me stranded. This is because I use those Mr tuffy tire liners in the front.
:lol: :lol:Merlin said:iam a co2 guy...
i carry 3-4 caps with me. had only once a flat tire....worked great.
ok, i needed 3 caps but its the easy way.
got a flat. a complete 20g cap in the tire and fast as you "can" ride home.
BCTECH said:got a flat tire 8-10 miles away from home, had to push that heavy bike all the way. terrible experience. I thought MC tire/tube was pretty strong so I didn't carry a spare tube/pump with me.
which tube do you guys use that has best quality ? I was using bikemaster but now want something better. will the HD version help? I understand it is heavy but I rather carry 1-2 lbs more than get a flat like that.
do you guys carry a small pump / Co2 or extra tube on your ride? changing mx tube on site might be very difficult, do you suggest carrying a bunch of co2 is a good idea?
macribs said:@Chalo, why put yourself through all the agony? Tubeless is king.
