FluxZoom
Offroader said:Also, I highly recommend you get a spoke torque wrench when building your own wheels. You can't do this by feel very well, trust me and don't think you can unless you have built 100's of wheels. The Torque wrench will guarantee you get the proper torque spec for each spoke which is around 30 inch lbs if I remember correctly. The wheel won't come untrue.
There is simply now way of knowing how tight you have the spokes unless you use this. You will most likely not tension high enough and the wheel will come untrue.
I personally use the Buchanan spoke torque wrench, but I guess you can use what ever motorcycle one will work with your spokes. I like the buchanan design because it allows me to bring up the torque spec slowly, like to 10 inch pounds, then to 15, 20, 22, 25, 28, 30. This makes sure all spokes are equally tensioned.
http://www.convertunits.com/from/lbf/in/to/kgf/cm
Is that right that you put a maximum of 30 inch pounds or 5kgf on your motorcycle wheel spokes?
