Dark Knight
Rix said:SKN John, I didn't think you were contradicting, when I read your measurments, I realized I forgot to mention the size of the tires I was referring too. I know one guy had a 2.0 x 19, that thing is small, by MTB and MC standards. On the contrary, my 2.75x18 SR241 on an 18x1.4 rim is bigger than your tire, by 1/4th of an inch. Your 2.25 on a 19x1.4 rim would be much better than on a 1.85 wide one. The 1.85 will spread your tire out and make it wider and slight more flat on the top tread, as the 1.4 it will be more rounded. You would need to see them at the same time to see the difference though. Probably the biggest advantage of running 1.4 wide rim over a 1.85 is the 1.4 is over 1 pound lighter, thats what I noticed between my 18x1.85 and 18x1.4 rims. Either way you go, you will like it better than a bicycle tire.
Rick
Rick - what's the weight you make for the 19x1.85 rim compared to the 19x1.4? I understand c.1lb different...but what are the actual weights of each? Presumably both are Pro Wheel? Apologies if this is already answered - reread a few pages of the thread but couldn't see it anywhere... Just wanted to compare them to the 'cheapie' 19x1.85 oz rims that I goit - and these weigh in at about 6.2-6.4lbs a piece... Gonna try and get my A into G and take some pics to post of them including spoke holes etc. as interested to see how they compare to the almost ubiquitous prowheel rim.
DK
Edit:
Damn - just notice you've got 18inch rims so won't be an apples to apples comparison.
Anyone else got a bare 19x1.85 prowheel they can throw on the scales and let me know the weight?
