I´ve been lurking around the forum for several months, gathering opinions about different frames, components, etc.
I ended up with Nyx, mostly because of the light weight and big volume.
As it turns out, they also offer great service and they are continuously developing new parts for the frame, protection plate for the adaptto controller, spacers for different motors etc..
1 of the bikes will be my main commuter, second bike is for girlfriend or friends who wants to join me.
They will mostly be ridden on asfalt and occasionally some enduro and mx.
1st rev of bikes will be to just make them work, test everything out and see what is up for improvement.
2nd rev is to ventilate the motors, tune the suspension and geometry.
3rd rev is water or fan cooling, or any other mod that will improve performance.
Final stage would be to mount everything inside the frame, if possible =)
Quick spec:
2x frames, 1 equipped with schlumpf high speed drive.
Mxus v3 motors.
Adaptto max-e motor controller.
Battery by forum member Prensel.
20s config.
Samsung 30Q cells.
Hope Pro 4 front hub, with 507x39 rims, same as for rear.
Hope 203mm brake rotors.
Shimano Saint calipers and levers.
Rockshox boxxer fork.
Fox DHX rear shock.
Shimano saint pedals.
Rental high rise fatbar with six pack racing integrated stem.
Various custom 3d-printed and cnc´d parts.
Micro controller to make the bikes "legal" and control pas.
Frame 1 arrived
2nd frame
Spring upgrade for the boxxer
Front assembly
Test fit
8awg phase wires with XT150 connectors
Test fit of controller
Had to modify the bracket to fit my shock
Cutting holes in this frame is not so fun =)
Speakon charge port
Wrapped phase and halls cables
Quick model of the saint lever to test the variable regen
hall sensor mount for saint lever
Bracket to mount the Nyx protection plate underneath the frame, will be glued to frame and bolted to the protection plate
Wire guide for phase cables around the bottom bracket
Battery and charge wires trough frame, will be glued to frame and shrink wrapped to wires
Bottom bracket wire guide done, printed in nylon on a SLS machine
Battery config tested before ordered
Protection plates from Nyx
Arduino to handle the legal stuff, will be mounted inside the adaptto display
Quick spec:
Mxus v3 motors.
20s config.
Samsung 30Q cells.
Fox DHX rear shock.
Frame 1 arrived
2nd frame
Front assembly
Test fit
Speakon charge port
