HAL9000v2.0
Actualy , just few day ago I was reading new patent database and there is about 20 very similar designs. Realy do not see what is the main difference that gave them right to have patent on souch a simple design??
HAL9000v2.0 said:Yesterday I tested some primitive RD system with my HXT and some chains and there is a problem. Setup is made so: motor turns CW lower speed via gearbox, motor turns CCW higher speed via chain. switching is made with two relays that changing 2 fazes of the motor. Controller is this one:
Switching is made by a siemens plc that meassure ressistance of a pot on servo tester, and when it is zero, switch to another direction. Problem is when changing from ccw to cw then motor made click sound, makes few ° in cw directions then go backwards. When the motor is running cw it changes to ccw with no problems. Can't figure out what is the problem but I suspect it is the shity controller ?!?!?
lawsonuw said:I've got that same controller. Did you get the USB programming dongle? The USB dongle looks like a simple USB to half duplex ttl level rs232 serial adapter. The PC program for setting up the controller allows the direction of the motor to be changed. This has been very reliable for me, though I've never switched directions with the motor still spinning. (switching the phases with a relay should be the same...)
Additionally the PC program has a testing mode that will run the controller from the PC and report motor rpm once the motor's pole number has been entered. If I make a retro-direct transmission I'd strongly consider using this controller and have my supervisory microcontroller always run it in it's PC setup mode.
Lawson
P.S. BINGO (only chip on the dongle) the PC setup program does speak serial.
Miles said:You certainly don't want to go through a double stage to get a 1:1 ratio...........
Miles said:You could do a spur geared variant of the Evo type transmission, with a 2-way clutch and 2 freewheels, or a chain and sprocket version....
No, I haven't actually built anything much, lately....John in CR said:BTW, do you have any of the designs you've shared in the build stage yet, or just sharing?
