John in CR
100 TW
d8veh said:That's much too much. Don't add any more or any copper wire. adding solder to about 1/4 of the length increases the current up to 20A, which is about as far as is safe for the controller and motor. You could be as high as 24A. If you have a wattmeter, you should use it to find out what you've got, and then adjust accordingly.docnjoj said:Thanks S/M. I have already soldered half the shunt and may go after it with some copper wire wrap, a la John in CR. The solder doesn't seem to have done much as the build in wattmeter in the LCD-3 shows about the same readings as before I soldered the shunt. More is better, maybe. If it can kick the shift point up a bit in low gear it will serve it's purpose.
otherDoc
I've soldered the shunt on at least 30 controllers and never had a problem. Many of them already had some solder added by the factory. I'm not convinced that what Jeremy Harris said was correct, neither do I see a necessity to wrap wire around the shunt. The method of just adding a bit of solder up the leg is simple, effective and quick. I personally don't see any reason to make it more complicated.
Solder is relatively high resistance and is a very inaccurate and unpredictable method of modifying the shunt. Spinning mags didn't list the complete mod, because it's quite simple and the primary benefits are that it's accurate and you don't have to worry on high power rigs that sold melts and runs killing the controller.
If you want to increase current from 15A to a 20A limit, then you simply reduce the shunt resistance by 25%. I would accomplish that by effectively reducing the shunt wires' length by 25%. Do this by wrapping 1/4 of the length with thin strand copper, and then soak it with solder. That makes that length of the shunt essentially 0 resistance.
If you have any old blown controllers, you can also rob a shunt wire from one of those and add it to the mix on the new board. That can often be the easiest when you're tight on room (shunt not near the edge of the board), by installing that added shunt wire on the bottom of the board. Just be careful that it doesn't stick down too far and short with the casing.
John
