Alan B
Normally you might have to choose top speed and hill climbing in a compromise. With this motor you get the 1.8:1 two speeds to help with that. So you can choose winding/wheel size for a top speed on level pavement, and use the low gear for climbing.
Mid drives are nice, with lots of gear choices. But the useful range seems to be limited to less than 3:1. You can get a little over 3:1 if you use an 11-36 or wider gearset, but realistically the USA power level mid drives don't need that wide a range. With my BBSHD I don't need to use the lowest couple of gears, and for decent chain life one should not go much below 14 teeth, so the range needed seems to be less than 2:1.
So the Xiongda is rather like having the highest and lowest useful gears of a mid drive.
