John in CR said:
May your little Bafangs last as long as I know my DD hubbies will. Too bad that BPM is sensorless.
I hope they last as long as DD too but I doubt it. In the long run, the DD should be the winner due to less moving parts. If I get
another year or two more out of the Bafangs, I'll be happy. They get used a lot. The only partial complaint I have is that when it gets
below freezing or very wet outside, I've had to treat them with ACF-50 or Fluid Film to keep the engine internals from shorting.
http://endless-sphere.com/forums/viewtopic.php?f=2&t=12984&start=60#p218898
It mainly seems to be in freezing weather when the bikes are stored outside. When the motor cools, condensation gets into
the motor. The treatment does keep them going. credit for this trick goes to Affliction - if he's still around.
I you're not running the BPM much over 20A 60V, I wouldn't worry to much about it being sensorless if you can get a controller
from ecrazyman/kewin. He hasn't got back to me lateley though, so I don't know if he's still around either. The 350W 20A
sensorless controller works great. I can't really tell it appart from the hall controller anmore, now that my batteries don't come
off the charger as high.
Just for more info on the Yardworks batteries and the Yardworks chargers. The 3S (batteries) 15S (cells) pack has never
measured more than 61.5V off the chargers. You can charge with them all hooked up and the controller on even! If anyone
is going to use one of these 20A 350W Infineon's with Lipo, I would recommend undercharging a bit. Lipo recommended
max being 4.2V x 15 cells = 63V is too borderline for the 63V capacitors most of these controllers will have. I would not
charge the pack over 62V or over 4.13V per cell. Might be better for the batteries in the long run too. I will probably be
trying this over the next few months myself. Will let you all know how it works out.
jbond said:
The only curious bit in this is what happens to motor temperature if you run for a long time at 54v-20A.
That's a KW of input power to the controller, so maybe 900w to the motor. At max efficiency that's 150W of waste heat in the motor.
If you can get away with it, that suggests that a 48v battery with the same current limit should be ok with some headroom.
Not sure about this motor math. Are you saying that you're wasting energy dumping 60V (61.5V off the charger) into
the motor. From experience riding with my son and a 40V pack, we get about the same distance going full speed...?
Or close enough not to worry about it. Oh, the motor does not heat up at full throttle up 5-7% grade with either 40 or 60V packs.
With the 30A controller, both packs caused overheating problems in the motor and the controller. I wanted to reprogram the
controller with a 20A current limit, but no one would get back to me with the original Parameter Designer programming
parameters to modify and re-flash the controller with. Anyway, the two small 20A controllers work great.
