D-Man said:Testing pictures:
Here is a crack that you get if you tighten the bolts too much. And a side shot.
LI-ghtcycle said::
Maybe you can use some glue that is similar to the stuff they use to repair windshields? Something that fills and seals to keep those cracks from spreading. .
AussieJester said:LI-ghtcycle said::
If the fairing is plastic that 'glue' wouldn't work well at all.
If it was mine, and it is acrylic perspex i would be cutting a disk large enough to cover the cracks (an acrylic washer if yu like) then fix them to the windshield using either Acrifix123 or some Weldon13 cement. Glue doesn't work on plexi you must use acrylic cements.
KiM
D-Man said:The material is vivak. They say its similar to pete1 plastic. Its got 2 mounting holes that have the hairline cracks. It kind of cracks like car windshields do but isn't a full break yet. Just a warning sign. This is not a zzipper. Its homebrew. So which glue works on this when the cracks have full separation? (Weldon 16, Acrifix123 ,Weldon13) I assume this is order only stuff or can you get it locally? I'm using metal rivot type nuts and bolts purchased at the hardware store plus loctite. Expensive little buggers. Just using whats available.
