Several “ifs” about relying on pack voltage to determine LVC/HVC (low/high voltage cutoff).
“If” your cells are healthy, balanced and stay that way, pack voltage may be a reasonable method for LVC/HVC. It’s better than nothing but what happens “if” one cell dies a sudden death and shorts, which is the way majority of cells seem to suddenly fail?
In that condition, your pack voltage is assuming 20S but in reality it’s functioning as a 19S pack. If you charge in that condition your charger stops around 84V. Divide that 84V by 19S = 4.42V/cell. That’s a very dangerous voltage range to have RC Lipo. Similar things can happen on the LVC side too.
This is why individual cell voltage monitoring like what a BMS does is much preferred method of LVC/HVC. They’re not perfect either but they’ve saved my bacon many more times than they’ve cooked it.
But you don’t need to use BMS. You can be the BMS by careful monitoring, pack health testing/qualification, perhaps install some cell alarms the RC guys use?
I’ve ran “naked” before and probably will again but it’s always gotta be in the back of your mind how cells can get skewed and things turn ugly very fast.
Here’s your video imbedded.
[youtube]J_oKpOSzJpo[/youtube]
Those BM6’s are shitty, inaccurate devices and work on the “bleed” high cells principle which IMO is a dumb way to balance Lipoly/Li-ion packs.
Ideally, good cells should rarely need significant balancing and if they do, I’d 1st look into why before dicking around with bleed balancing.
