I have two Li Ion packs that I need to connect together and was wandering what is the max capacity difference in percentage that is acceptable for connecting uneven capacity packs in parallel.
Let's say a system draws 100A from a 50Ah battery and I connect a 100Ah battery to the 50Ah.
I don't really see the problem as they share the same voltage and also more current will flow from the larger battery as it has less resistance.
But at some point if the capacity difference is very big the higher capacity battery will charger the lower capacity battery as they deplete unevenly, am I correct?
