I am trying to setup my electric scooter with two hub motors, two controllers, one throttle and one battery pack. The throttle is a twist one with just battery indication. The motors are the same 36V motors and the controllers are both 36V as well. The throttle connects to one controller in the picture, with red white and black going to a three prong connector. Then the yellow and green from the throttle go to the another red from the controller and the brown from the throttle goes to the Orange of the controller. For the second controller. There is a three prong port for the throttle which is red black and green. There is also a brown wire, two white ones, and a purple one. I connected them both the the battery and they both receive 36V. Then I connected the white throttle wire (signal) to the original controller and then forked it to the other controller, but did not connected the throttle to the black and red of the other controller because it doesn’t need two power sources. When I twist the throttle, the one motor runs on the original controller, but the secondary controller that is only getting the throttle signal doesnt do anything and the motor doesn’t spin. I measured the voltage on the signal from the throttle and both controllers get around 1-3v depending on throttle rotation. Why is the second controller not responding to the throttle. Are there more connections I have to make between the two? Please help View attachment 2View attachment 1
