Hi guys
I have a qs205 in an eeb frame and I was currently using a single shimano bmx freewheel. I didnt really want to remove it because its of much better quality and super quiet. But for versitility, i decided to try this 3 speed freewheel..problem is that its a cheaper non branded version but I figured having 3 gears would be better than 1. Plus this 3 speed freewheel is the exact same width as the single shimano.
https://s.click.aliexpress.com/e/_d7U9p3L
Problem is there are no notches for a removal or installation tool only 2 little holes. I assume the arrow is to remind you that its clockwise so I installed it by hand as tight as I could. I tapped the holes a tiny bit clockwise as well with a hammer and flat screwdriver.
Has anyone removed one of these? Im guessing counter clockwise on the 2 holes and take it apart and destroy it piece by piece???
Its cheap so no matter...but just a hassle if that how you do it
