pishta
New-ish here
according to the math, this will only draw about 21A but am not sure what these pull on initial start up. Im attemping to build a pack for this hub motor combo using some harvested 18650 batteries. I got 5 different 18650 battery makes ranging from 1.5A to 10A discharge ratings. Im not sure how the discharge rating is factored into a pack setup. If the BMS can allow 20A+ to the motor, what should a single battery in a 13s6P be rated for? Does the 20 get divided across the 13 series cells for <1.5A each or is it some parallel formula? The 10A batteries are E-bike pack: light blue LG LGDBMH11865 with discharge capacity
and I have 5 and 6.5A batteries too. Most of the batteries came from physically damaged E-bike batteries besides the 240 1.5A cells that came from 30 small 4s2p UPS systems. I built a 10s2P pack for a small 36v scooter out of the 1.5A batteries before I knew the A ratings and it sucks. It never charges to full green according to the 3 light scooter meter and it has no power and yellow drops to red battery as soon as I goose it. All the 1.5A/2400mah batteries I used tested >2400 mah on my lipo battery charger/capacity tester.
| Discharging: | 2.50V Cutoff 620mA Standard 10000mA Maximum |
