bigsi
I've bought the LG 18650 hg2 cells. 7ah discharge gives 3.3ah 5amp discharge gives just under 3.5. Bought for £3.1 delivered a' cell
nukezero said:So after reading all 3 pages, what's the concensus?? Forget about money. I care about density and power to weight ratio. Is the 35E holding up to 29E?
tumich said:Look at this capacity tests did on iCharger208B (not by me). 35E aren't bad like on dampfakkus.de
Also try to match discharge curve over the complete cycle of existent pack. You can try asking DarkAngel for help, he may know right cell from memory, or compare discharge charts he makes.Vortex99 said:Hi!
I have one Vectrix with 6.5kwh with this Cells (samsung 35€) and i want increase the battery pack capacite, but the price on NIKON for this cells increased too much... It's possible adding more 2KWH with other 18650 cells??
Vortex99 said:What do you think about panasonic 18650PF (2.9ah) and panasonic 18650B (3.4ah)?
Price is very dependent on sales/production volumes.markz said:Can someone explain why a no-name/generic brand is more expensive then a brand name. MXJO, EagleTac, Enerpower.
smeagol222 said:I've been trying to find out what the values for "fast charge" are.
https://batterybro.com/blogs/18650-wholesale-battery-reviews/40773059-new-lg-mj1-18650-battery-review-3500mah?comment=2952010636#comments
battery bro says MJ1 supports this, but spec says 1C which is 3.5a right?
https://www.nkon.nl/sk/k/Specification%20INR18650MJ1%2022.08.2014.pdf
Just to confirm- this number doesn't get changed depending on the battery configuration 72v 20S10p / 18v 5S10P
I'm working with these on a new build, and I just want to know what amps I can balance/fast charge/bulk charge with.
