Ohms_Cousin
🔌 New-ish
- Joined
- Aug 17, 2019
- Messages
- 17
First off, newb here and just starting out on the learning path. So please excuse the dumb questions I may ask.
I am wanting to put an electric motor setup in my sail boat.
I have selected Agni Motors Pancake motors (axial flux) - these motors have been developed in conjunction with Cedric Lynch, the inventor of the so called Axial Flux Pancake motor.
I will be running 2 x 8kW motors - I am buying the plans to make the mount for the motors and the reduction gearing etc.
I need to select a voltage to run at. I was initially going to use 48vnom as my inverters are 48vnom and it makes sense to try to keep voltages on the boat to a minimum. Then there is the safety aspect - 48vnomn is regarded as "safe" although I wouldnt want to get a bite from a 48vnom system !
After much reading I came across some info that said that the heat output from a 96v motor is 1/4 the heat output of a 48v motor setup. Of course double the volts and halve the amps - that's always a good thing !
So what are the pros/cons of 96v Vs 48v? (72v also an option - although if going above 48v why not just to to 96v instead of 72v?)
What I know so far - 48v considered safe/speed of the motor is slower at 48v so reduction gearing is more manageable/lot more switch gear available for 48v compared to 96v.
In general is it wise or unwise to consider 96v over 48v? I am concerned about heat build up down in the engine bay of the boat (diesel removed for the electric) and if 96v really does run so much cooler it would seem to be the way to go.
I am wary of 96v "hazards" - however how big a problem is this really? The batteries will be buried under the floor with limited access so there really is no way that anyone could accidently come in touch with a 96v battery system. The only time an issue could arise is when working on the system for maintenance / repairs etc - then it becomes a case of being VERY VERY careful and using the right safety gear while working on it and always having another person present to hit a kill switch or similar to turn off the current if one does get hooked up.
One thing I do like about 96v is that it would be a 32S1P battery configuration - thats a lot of energy in the battery I will build. I have EVE LF304 LFP cells for the battery build. I intend to build 2 x 32S1P batteries - each on thier own BMS. (or 4 x 16S1P batteries at 48v if I go that way) - all of these batteries will be under the floor out of the way.
I am sure that many have been down this road before and have experience of the issues I am considering.
Looking forward to be educated on this.
