drmacgyver
- Joined
- Mar 29, 2014
- Messages
- 189
psychotiller said:drmacgyver said:Pediglide said:maybe it'll be better to just use the MBS bearing and wrap the axle with a spacer with a bit of loctite inside...?
Or using the skate bearings you have there, find an aluminum or pvc pipe with a thickness that would fit the gap and shave a ring off the end of the pipe?
That's exactly what I was thinking. Then also get some washers with 8mm id/ 28mm od to cover/keep the pvc seated. Good Job drmcgyver!
Thanks!
