torqueboards
psychotiller said:They fit too loosely. Guess I could tape them but I would rather have a perfect fit.
How loose are they diameter wise I assume? Can you post a picture?
torqueboards said:psychotiller said:They fit too loosely. Guess I could tape them but I would rather have a perfect fit.
beetbocks said:i don't want to hijack your thread but i have redesigned the alloy 3 piece wheels to be more simple and i can get them for about £25 each - they will fit standard skate bearings and fit a standard skate truck..
Skike now sell the 5" tyre pretty cheap. http://www.skike.com/shop.php?l=en&c=UK&page=5&cat=1&sub=0&go=5.
I have some on order so ill let you all know the quality of them.. I do find the 5" to be better all round tyre than the 6"..
Do you think these numbers add up? would you pay that for the alloys?
I must add ,out of all my build the 5" tyre commuter is by far the most versatile of them all.. the ride is just super sweet and smooth..
turbobikekit.com said:Are these wheels with the hub having freewheel?
When the throttle is off the skate can roll over?
Thanks
scoot-e said:DO NOT USE THESE 6" WHEELS - They will crack and fall apart as soon as you go over a curb or bump - the plastic is not a durable nylon or other strong material like razor or MBS uses, it is a cheap hard plastic that shatters and is used for 2 mph non-electric wheelchairs or the like
http://www.accesscasters.com/6SPNGBS-6-inch-Grip-Ring-Stem-Caster-Black-Pneumatic-Wheel.aspx
I bought several and the first curb I hit at like 5mph it shattered the rim, exposing the innertube which burst out and popped and ground my 2 wheel scooter to a halt, luckily I was going slow and it just tipped the front end into the ground and I didn't get hurt. Yes, they're inexpensive wheels and readily available but I highly recommend against it out of my own and many others personal experience...
Will try to post a pic shortly of the cracked rims...
psychotiller said:Right. Use these: http://endless-sphere.com/forums/viewtopic.php?f=35&t=60449
psychotiller said:I working on it. Unfortunately every quote I've been getting back from suppliers has been almost double what I paid last time....I cant afford to personally fund 8000 pieces just to save a few interested friends 75bucks. And a kickstarter campaign for 6" wheels seems goofy to me. I can get a few sets made right now, but the cost (and I mean cost) is $275. (tires/tubes, hardware, pulley and hubs)
They're center set which will most likely work a lot better on your scooter. Also, the hubs are 36mm wide and will accommodate 1.3" to 2" tires. Solid and nice.
Let me know and I'll set it up.
torqueboards said:Looks like you might need to drill out your own pulley.
Tamatoa said:torqueboards said:Looks like you might need to drill out your own pulley.
I thought I would have to do that but I hoped there was another solution, thanks for your reply anyways, now I know that I do not need to waste time looking for a plug n play solution.
Tamatoa
Tamatoa
scoot-e said:Tamatoa said:torqueboards said:Looks like you might need to drill out your own pulley.
Tamatoa
Those are decent looking hubs/wheels
Do you have a link to where to purchase them, Tamatoa?
Thx!
psychotiller said:Tamatoa said:torqueboards said:Looks like you might need to drill out your own pulley.
Tamatoa
Rather than sand those wheels, maybe you could take them to a machine shop and just have them milled down a little bit.
