dazzassj6
hey guys, i just recently installed my 500w cyclone motor kit. i equipped it with a "24 volts 20AH 13C 260Amp SUPER DISCHARGE BATTERY SYSTEMS" " 50-100km per charge"
Its one of these ones
I just dont get it.
Problem 1:
when i bought the kit, they said the 500w motor is a 2500rpm reduced to 300rpm motor. I heard its higher in torque so im guessing thats what caused this to have a lower top speed. However i noticed it doesnt have much climbing ability either because it doesnt have a high RPM it goes very slow on a larger gear and wen on a smaller gear it has very little climbing ability. So its shit climbing hills.
I rode it on flats from A to B (less than 5 km) and noticed that the battery aswell as the motor is very HOT. I read somewhere here that the motor is usually only warm.
Problem 2:
In this trip less than 5 kilometers, the battery died on the way home!!!! IT was a fully charged battery when i started the trip. I cant believe this high quality 20ah lifepo4 battery can only last this long. I also noticed that when i charge this battery the charge would only take like 2 hours or so to fully charge it from 0% to 100% as indicated on the charger. It is a 5 amp charger. After its 100% the charger shuts off into green light.
So what could be that is making this motor drawing this much power to make it this hot? My motor is a little misaligned from the chain wheel and sometimes the chain jumps from the motor. Oh and the freewheel on the motor can come off is this normal? it tends to slightly move up because of the misalignment but im scared it might fall off, dunno what i should to secure it. Any clues on this one ??
thanks in advance guys!
link to photos of the bike here
http://www.endless-sphere.com/forums/viewtopic.php?f=6&t=6669
UPDATE: Problem lies in the battery. There is no BMS!!!! Just received the new BMS but i dont know how to install it please help!
I just dont get it.
Problem 1:
Problem 2:
