D-Man said:Ok, just got back from a couple runs. With only 1 nicad pack hooked up, Voltage was around 55 volts. No load speed was 30.9 mph. The bike ripped a 24.8 mph pass at 40 psi. Did it again, same speed. Man was it fun! What a difference in acceleration! Think I'll have to rig a switch or something.![]()
Lowell said:D-Man said:Ok, just got back from a couple runs. With only 1 nicad pack hooked up, Voltage was around 55 volts. No load speed was 30.9 mph. The bike ripped a 24.8 mph pass at 40 psi. Did it again, same speed. Man was it fun! What a difference in acceleration! Think I'll have to rig a switch or something.![]()
Booster packs are addictive aren't they? Pretty soon you'll simply want a higher voltage main pack :lol:
Don't think I've seen to many small digital volt meters.
Toorbough ULL-Zeveigh said:zatz vye
eye zay.....
TOORBOUGH ULL-ZEVEIGH!!!
Toorbough ULL-Zeveigh wrote:
zatz vye
eye zay.....
AH HA! NOW I get it!
Reid Welch said:Finally I can give up respecting the presumed exotic ethnicity...
or is that ethotic exnicity?
To make up for it let me help you out with the pronunciation of 'xyster' with a little help from german inflection. If I've followed his posts on the subject correctly, then a suitable rhyming pnemonic would be 'xyster-meister'. Hope I got it right!
xyster said:Toorbough ULL-Zeveigh wrote:
zatz vye
eye zay.....
Call me dense, but I don't get it yet.
Turbo That's-The-Way?
Turbo Rides-All-Day?
Turbo Outta-My-Way?
Turbo Pulls-One-Way?
Turbo Goes-His-Own-Way?
Turbo Knows-The-Way?
To Go Up, Up, & Away?
Turbo Rules-The-Lane?
Turbo Rules-The-Day?
Turbo Uses The Right-of-Way?
Turbo's A Fool Today?
Turbo's Cool That Way?
Turbo Swims-The-Bay?
Turbo Schools-The-Way?
Turbo Shoo's Flies Away?
Turbo Pulls-His-Weight?
Turbo Shovels Hay?
Turbo Needs-A-Lay?
Turbo Goes-Both-Ways?
Turbo Could-Be-Gay?
Turbo Pulls-Wheelies?
Turbo Rolls EV's?
C'mon,
Toorbough ULL-Zeveigh, help me please!
You're overthinking this.
Just clear your mind of all distractions & let the gutteral Austrian baritone reverberate thru your head as you chant the mantra...
toor-bough-ull-ze-veigh...
