72V / 40A DC toggle switch
Bokonon
Sacramento
Hi all.. I've looked far and wide and I can't find a switch that will work as a 72V/40A DC cutoff. This is for a Cyclone with a 72V battery.I have a "soft power" on/off switch on the controller, but I would like something to cut the battery power when I need to. Right now I'm just unplugging the XT60 connector to the battery every time I put the bike in the garage and it gets kind of old.
Is there really no such thing as a toggle switch that can handle 72VDC and 40-60 amps or so?
Problem with DC toggle switches is that its hard to get the contacts apart, unlike AC when the current is at zero X amount of times in a second makes it easy to get the toggle contacts apart. Plus there is the arcing that happens on the contacts which can cause problems too.
I found a 40A DC toggle switch for $25usd - Item Specifications Here
https://www.mouser.com/Circuit-Protection/Circuit-Breakers-Accessories/Circuit-Breakers/_/N-axfui?P=1ypvfz0Z1yx4attZ1yzub35Z1ytjthy&Keyword=40A+toggle+switch&Ns=Pricing%7c0&FS=True
Switches rated for high current *and* high voltage are rather large, of necessity. You can find them on Mouser, Digikey, Farnell, etc., though it will take a little while to poke thru the listings.
As long as you are NEVER switching under any load, you can use one of the breakers like I use from an old powerchair (28-29v max system). It's capable of 83A IIRC, before it would pop as a breaker. The on my trike's 14s (58v full) pack doesn't get used as a switch often, but I used one just like it multiple times a day for years on CrazyBike2 with the same voltage.
This is what I'm using; it's in a different spot now, but works the same:
file.php
file.php
They are a bit on hte large side, but I also have pulled over 100A for seconds thru them, and peaks of a couple hundred amps for a second or less during certain testing:
file.php
You can also use the battery cutoffs like Harbor Freight and other places sell, to switch a battery in a car, boat, RV, etc. off. I'm using one of those on the trike to switch the system off multiple times a day, for years. Again, no switching under load. Better than a switch, because without the "key" you can't turn it on. ;) Most people (even thieves) probably don't carry one of those around with them.
it's in a different place now, but this is the one I'm using:
file.php
The problem is only if you use it as a breaker (switching while current is flowing at a high enough rate), at a voltage higher than it's rated for. That can allow the current to continue flowing *even though the switch is open*, causing an arc across the contacts, which is basically the same as a welding arc, and can thus heat it fast enough and hot enough to cause a fire.
Not a problem as long as you're only switching when current isn't flowing.
The stuff made for solar or marine use will likely be more robust than that for automotive uses, but also probably more expensive. Probably worth it. My breakers are just salvaged from old powerchairs (as are most of my Anderson connectors and heavy gauge wiring), and they work fine so far...but they're not used as breakers.
Thanks for this! A lot of good info here. Another thing I found is these "DC isolator" switches for solar panels but they are really expensive (> $50).
