zombiess
OK, decided it was time to brush up on my 3 phase operation and figure out if this is fact or fiction. I believe I have the basics of 3 phase operation down but I need to understand why some controllers will PWM one side but not the other and if that even matters for controllers that use the same mode of operation as the Xie Chang based ones currently do.
Keeping PWM on the high side helps to deal with low inductance by keeping the current from spiking out of control due to being interrupted frequently, the more frequently this happens the lower the current peak reaches, how high it gets is determined by the inductance, lower inductance equals higher di/dt which means lower inductance motors spike faster and need more control. The low side on the Xie Chang controllers many of us run is fully on. If I have my 3 phase BLDC commutation correct that means that any phases low side experiences the a full on time current for the 2/3rd the time it takes a BLDC to move to the next commutation block. Therefore the more poles the shorter this time of stress is on the low side FETs (or high side FETs if they are held at 100% PWM).
If the high side is in PWM and the low side is just held on, isn't it too under the effect of PWM since the PWM'd high side is completing the circuit through it.
i.e.
Phase A in PWM
Phase B full on completing the circuit from A to B
Phase C Off
next step
Phase A in PWM
Phase B Off
Phase C full on completing the circuit from A to C
Next step
Phase A in OFF
Phase B PWM
Phase C full on completing the circuit from B to C
etc
If this is infact the case, then holding the PWM to 99% on the high or low side (depending on what the controller does, high side for Xie Chang aka "Infineon") should protect both the low and high side FETs.
Going to full block commutation at 100% PWM aka no PWM works OK on what most consider high inductance motors with many poles because the controllers limit the input battery current and output phase current.
I am bringing this up because I was looking at one of my test controllers I destroyed the low side FETs on and some discussions I have had with Arlo1 and John in CR. I am continuing to work on some 3 phase driver / power stages and want to make sure I have my theory of operation correct, at least for this simple method of control.
I believe I popped the low side because it just happened to be weaker than the high side. All 3 FETs failed on the low side and it was a cascading destruction as noticed by the failure being more severe sequentially from left to right leading me to guess the far right FET (the one with the least damage, a very tiny hole) occurred first until the last FET, the left most one with a hole the size of a pin head and the middle one having a hole in between the size of the other 2. This was a minor failure by board standards, no smoke soot or bangs, just stopped working after I programmed in some ambitious settings and got on it hard from a dead stop with a 30uH 23 pole motor, controller was set to 99% PWM.
i.e.
Phase A in PWM
Phase C Off
next step
Phase A in PWM
Phase B Off
Next step
Phase A in OFF
Phase B PWM
etc
