bigmoose
Here is the spreadsheet again to play with. I have added a few more motors. It is in a zip wrapper, just unzip it to get the xls spreadsheet.
View attachment MotorCurrentsV3.ZIP
If I build a working 300a 135v power stage I could sell to the masses for $400
$400 for all the r&d and all the work zombies puts into that is a HUGE discount already.speedmd said:If I build a working 300a 135v power stage I could sell to the masses for $400
Remember your friends here on ES with some possible big discounts.![]()
If I build a working 300A / 135V power stage I could sell to the masses for $400 vs someone buying the cheapest Sevcon, what do you think most people would buy?
spinningmagnets said:If I build a working 300A / 135V power stage I could sell to the masses for $400 vs someone buying the cheapest Sevcon, what do you think most people would buy?
If it was reliable, was plug-and-play with a limp-home mode...and was easy to program with a simple user-interface...you could charge a lot more than $400...
Reading Lukes posts about the controllers he tried to get to work gave me a headache...
what type of failures could you suffer while in "limp home" mode? how do you see this working?limp-home mode
If I remember correctly, the guy had a 2nd motor controlled by a 2nd throttle, which he used to start (the motorcycle) from a stop and only then "engage" the main motor. The high priced controller was a Kelly, the brushless controller was one of big ones from hobbykinkg. His motor was 36V, so he could use the brushless controllers.John in CR said:There's also the guy who made his own brushless motor, and found it to run much better using 6 or 7 sensorless RC controllers, each powering a stator tooth or two per phase, than it did with a high priced 3 phase controller with hall sensors.
simply change the motors so they require multiple tiny cheap sensorless drives instead of building monstrous high priced drives
HighHopes said:here's what i learned "you get what you pay for"
Njay said:If I remember correctly, the guy had a 2nd motor controlled by a 2nd throttle, which he used to start (the motorcycle) from a stop and only then "engage" the main motor. The high priced controller was a Kelly, the brushless controller was one of big ones from hobbykinkg. His motor was 36V, so he could use the brushless controllers.John in CR said:There's also the guy who made his own brushless motor, and found it to run much better using 6 or 7 sensorless RC controllers, each powering a stator tooth or two per phase, than it did with a high priced 3 phase controller with hall sensors.
Nope they use a shunt to measure DC current.HighHopes said:do the china controllers not measure phase current? it's staggeringly simple to control torque so it is not going to wheely at start and smooth during the rid if you measure phase current in a closed loop fashion.
Arlo1 said:Nope they use a shunt to measure DC current.HighHopes said:do the china controllers not measure phase current? it's staggeringly simple to control torque so it is not going to wheely at start and smooth during the rid if you measure phase current in a closed loop fashion.
I don't have a eb3xx that I know of Mine are all older. I would be interested in testing the EB3xx 18 fet you have and send it back If it looks like I can run a hard motor I will try with your permission...zombiess said:Try out an EB3 board, they are doing something different, modding the shunt has no effect on phase current, but I don't know how they are doing it. All phases have a small inductive/resistive type trace coming off them through a transistor that the EB2 boards don't. This is one of the things I would like to measure, EB2 vs EB3 phase current overshoot and control. I'd like to see some solid numbers. I can loan you a 18 FET EB3 controller to you if you want to test this. I have an 18 FET EB2 controller but it needs it's FET's replaced, installed into a case / etc. I'm guessing you are using the older EB2xx board in your videos? Do you have any EB3xx boards you can test with?
zombiess said:Fechter, have you looked at an eb3 board yet? I would like someone to help figure out why modding the shunt doesn't alter the phase current the same way an eb2 board does.
fechter said:That sounds strange. No, I haven't seen one. There must be some other current measurment mechanism.
