Ferreira
The idea is, to keep the input of electrical power that is fed to the motor at 72V the same that it originally was at 48V during normal riding.John in CR said:What is it that you believe changing current limits to something lower during normal riding will accomplish.
That's right. Comparing one and the same trip at one and the same top speed, energy consumption should be virtually independent of acceleration and battery current limit. On the other hand, the batteries will live longer and provide more energy when discharged more slowly. The datasheet of my SLAs says that by reducing current to 2/3 of 22A, the time span I can draw that current nearly doubles.John in CR said:As long as you ride the same top speed It will have only negligible effect on efficiency, because it requires the same amount of work to accelerate to a given speed. Yes you use higher power to accelerate quicker, but it is shorter in duration. The difference only comes about because accelerating more quickly puts you a cruising speed for longer and therefore a higher average speed, which gives more back to the wind. As long as aren't pushing the motor into saturation at the higher current, then you aren't creating more heat. As long as you're not talking about extreme acceleration, being able to get up to cruise more quickly is safer and more fun. Once you set your bike up to climb that hill without heat problems, you're good to go for all riding. Zippy acceleration at no cost is one of the great things about electrics.
After I found out that there are Lithium batteries which don't need a battery management system and can be soldered not welded I decided to do that. I plan to order them soon, I have asked for a quote from keeppower.com.cn for Sony US18650V3 today.dnmun said:does it really matter? they are lead and have a short cycle life and since the lead is now more expensive than lithium it is the worst of all worlds.
if you are determined to use SLA then you need to reorient the batteries so that the electrodes are laying horizontally (like pancakes) when charging and discharging to extend the cycle life of the SLA.
