frodus
i keep looking for something smaller or something more sealed... might have to build it
To provide protection in a fault (output overload) condition,
the unit is equipped with internal current-limiting
circuitry and can endure current limiting for an unlimited
duration. At the point of current-limit inception, the
unit shifts from voltage control to current control. If the
output voltage is pulled very low during a severe fault,
the current-limit circuit can exhibit either foldback or tailout
characteristics (output current decrease or
increase). The unit operates normally once the output
current is brought back into its specified range.
317537 said:I Picked up an old AC welder for a song that can do 48v @ 80 amps with no sweat, you just need to rectify it. Those 3.3v and 5v DC conveters work most efficient at 36v anyway
You can controll the current on welder transformers just fine to over 120 amps..
The above pic is a DC welder. But you could do an AC welder cheaper and some 60 amp rectifiers and big caps, Mwahahahah.![]()
splash said:There are lots of adjustable dc to dc converters on ebay from china. Also there are power supplys 120vac to 12 vdc to drive the dc-dc modules. They are not expensive.
