Link said:
FWIW, the most I've ever seen anyone get out of regen on an ebike is 7%, and they were staying within the batteries' charging capabilities and using lithium (something like 98% coulometric charging efficiency).
johnb said:
So you are expecting to recover 70% of the acceleration energy when braking. I don't see any way of getting more than 50% efficiency during acceleration and regen, giving an overall recovery of 25%.
There are a lot of records on the web of designs to blend ultracaps into next-gen hybrids due to their ability to soak large regenerative currents - pure electric storage, low internal resistances of the newest caps. The regen efficiency estimate of up to 80% using ultracaps is discussed by people ranging from Honda (used it in their FCX vehicle) to EERE with the US Dept. of Energy. Most of the technical journal papers I have are copyrighted so I can't post them here, but a nice public-domain white paper is here from BGSU:
http://www.bgsu.edu/downloads/tech/file55534.pdf
Regarding a series hybrid bus, designed for the stop-and-go urban environment. Note the 150 kW regenerative power he has measured. That would destroy a lead-acid (and even moreso, a Li-ion) battery pack with a similar voltage rating to the capacitor banks. Jeff has designed, built, and tested these buses. He also happens to be the "guy in Ohio" I mentioned earlier who I hope to enlist in the EV-1's resurrection. ISE Corporation in California has also had success incorporating ultracaps on their hybrid buses.
Can (to scale) such high currents and high recovery powers be obtained using a hub motor and a suitable e-bike (maybe kit-based, maybe Kelly) controller, using a human switching system? I don't know, but I'd like to know. Given that I almost have what I need on hand, let's see what happens. I'm under no illusion though, Murphy's Law is suspended for no one. The way I see it, the efficiency of regen in the bike application will either be good enough or not, it will either be a limitation of the motor, the controller, or the human (or all of the above). Time to find out.
In the spirit of that, I think I'm about ready to pull the trigger on an order. Any objections to (keeping in mind all previous bits of advice):
http://www.goldenmotor.com/e-Bike-DIY/DIY-ebikekit.htm
700c rim (to fit my Rayleigh C-40), front wheel, 36V/500W, regen controller, twist throttle ($427)
Comments welcome as always! There are several other motor options there, by the way. If this controller can't do the high current regen, I'll get a Kelly next.
Thanks all, for so much help so far.
