Phdintheory
I got to thinking about it and I don't think I've ever even seen one of these before.
I brought it into the house to get a better look at it, take a few pictures, and do a little Google research.
Here's what I've got so far.
I believe it's a "Liberty" model 629.
If correct, this model has:
36v/10ah Advanced Lithium Ion HP Battery,
Efficient 350 watt brushless motor,
36V/15A Brushless controller,
Etc.
At this time the bike does not appear to have enough of a charge to operate, but all appearances indicate that this is only a power issue. Observationally the bike appears to be in working condition. (I do have question about the two wires coming from the ignition switch. Visible in the photograph, my thinking is that they probably went to a set of lights?)
The main issue I'm running into already is that I wasn't given any charging equipment for the bike. I wouldn't be too concerned with that normally as I'm pretty familiar with Ohm's law, however in this case, I am having issues trying to figure out how to remove the battery so I can examine it thoroughly as I build a charging unit.
I have downloaded a manual that tells me how to remove it, but it seems to be stuck or something.
All that said, I think my questions would be:
Is there anything about these bikes that I should be aware of right out of the gate? (Any "don't ever do's," or "Be sure that you..." kind of things?
What might those two wires go to and would they have anything to do with standard operation of the bike?
What might I be doing incorrectly when I've tried to take out that battery? it simply won't lift up and away from the bike. (Yes, I raised the seat.)
And lastly, does anyone out here happen to know the charging circuit design at the port on the bike? I've determined the polarity of the contact points, (One ground and two hot) but I'm unaware of which hot is going to be the charging circuit, or the regular power.)
Also, the voltages?
I know I'm asking quite a lot, but I assure you that any help will be greatly appreciated. I just want to see if I can get this neat little toy running.
Thank you in advance for all who help.
UPDATE!!! The pics are new. They aren't the ones the comments were about. lol
