DeathBlade
- Joined
- Oct 18, 2008
- Messages
- 111
I'm re-rebuilding the ebike again, the plan is to mount the 1hp scott motor to the frame down tube and use a single or 2 speed right angle gearbox to run the motor to the crank and use a free wheel front.
Here is crude drawing (paint I know) of what I was thinking of a set of either straight cut or helical cut bevel gears
driving a set of spur gears on a shaft actuated by a dog clutch.
Do you think the sprockets/chain on the bike can stand the motor 1hp 24volts over volted to 36volts there is should be 4500rpm at 150rpm/volt
So helical or straight cut bevel gears? And what place to get them other than ebay?
